Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Identify that you have the Holmes HEH8031 heater. The model number is on the bottom of the unit.
Place the heater so the rear housing is facing you.
Remove the eight (8) 1 cm coarse-threaded screws around the perimeter.
Remove the two (2) 7 mm machine screws in the center.
Using your fingers, pry bottom corner of housing open from bottom to top.
Turn the fan blade assembly over so blades are facing up.
Locate the four (4) metal tabs that connect the blade assembly to the rotor.
Using the pointed metal spudger, bend each of the four (4) metal tabs toward the rotor shaft.
