Введение
This guide will show how to safely remove and replace a faulty power cord on the Holmes HEH8031 space heater.
Выберете то, что вам нужно
Turn heater over so the controls are facing up.
Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
Decrimp the wire nuts from both wire connections.
Remove wire nuts to expose wire strands.
Separate all connected wires.
Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
Separate the two halves of the cord clamp and remove from cord.
Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
Strip at least 3/4 inch of insulation from the cord to expose bare wire.
Twist wire ends to form a tight braid.
3 участников успешно повторили данное руководство.
Один комментарий
Are there substitute power cord for Holmes HEH8031 power cord replacement?
