Введение
This is a very simple guide that will help you dissasemble and replace the motor of your Holmes box fan, this process is easy and it only requires a screwdriver and a new motor to install.
Выберете то, что вам нужно
The first step is to make sure you unplug your fan from the outlet.
Make sure you also unplug the power cord from the back of the fan.
Now that your fan is unplugged, lay it flat with the brand label facing upward.
Next is to remove the front cover.
Remove the six screws from the perimeter of the cover in order to remove the front cover.
Next is the back cover.
Flip over the fan so you have access to these six screws.
Remove the six screws from the perimeter of the cover in order to remove the back cover.
Remove these four screws in order to remove the motor and fan blades from the housing.
The next step is to remove the mounts that held the motor to the housing.
Remove these four screws to remove the mounts.
5 участников успешно повторили данное руководство.
4 Комментариев
Where might one find a replacement motor for a older box fan
Also, I would like to know where to get a replacement motor, as shown in step 4.
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
