Выберете то, что вам нужно
Homemade construction tool, for holding screws using 3 options, Neodymium Magnet, left side slot for 6 mm head screw and right side slot for 5 mm head screw.
Photo of materials to be used, there are more materials than those used in this design, since I have made 2 variants of the homemade screw-holding tool at the same time, in another document I show the 2nd tool. A 1x1x20 Cm wooden strip has been used, any other similar will work, Neodymium Magnet, and heat shrink tubing.
Neodymium magnet.
Wooden strip of 1x1x20 cm, the measure of 20 cm depends on the needs of each one, other measures can be used. I used the 1x1 batten that I had that was quite adapted to the idea of having 3 screw fixing points.
Cut the ribbon at 20 cm, the tip is cut at 45º to prevent it from hindering the insertion into the toaster.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
