Инструменты
Запчасти
Детали не указаны.
  1. Using a hair dryer on hot or a heat gun on low, carefully heat up the bottom foot for 1-2 minutes.
    • Using a hair dryer on hot or a heat gun on low, carefully heat up the bottom foot for 1-2 minutes.
  2. Using your fingernails or a guitar pick, separate the outer portion of the foot from the mesh and remove from the HomePod Be careful not to break the small tabs that position the foot to the bottom of the HomePod Be careful not to break the small tabs that position the foot to the bottom of the HomePod
    • Using your fingernails or a guitar pick, separate the outer portion of the foot from the mesh and remove from the HomePod
    • Be careful not to break the small tabs that position the foot to the bottom of the HomePod
Заключение
Nicholas Ouimet
Участник с: 16.10.2009
2 733 Репутация
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 61
