Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Open the hood by pulling the hood latch.
Chock both back wheels with blocks of wood to prevent car from rolling.
Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
Place the drain pain under the chassis and align with the drain bolt.
Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
Stop the vehicle and let the engine rest for 5 minutes.
Use the dip stick to double check oil level and add more if needed.
Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
Reset the oil life in the maintenance section of the vehicle computer.
6 участников успешно повторили данное руководство.
