Введение
Follow this guide to replace a worn or damaged carburetor on the Honda FC600 tiller.
Выберете то, что вам нужно
Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
Use your fingers to unscrew and remove the wing nut securing the air filter cover to the air filter elbow.
Squeeze the metal clip on the inside of the air filter cover and remove it.
Use your fingers to unscrew and remove the wing nut securing the air filter to the air filter elbow.
Lift the air filter straight up off the elbow, making sure it clears the threaded rod.
Use a 10 mm socket and socket wrench to remove the 25.5 mm-long bolt securing the air filter elbow to the tiller.
Use a 10 mm socket and socket wrench to remove the two nuts securing the air filter elbow to the carburetor's threaded rods.
Use a pair of snap ring pliers to loosen the spring hose clamp on the breather tube, pulling it out 2-3 cm so it's not clamping onto the end of the tube.
Pull the air filter elbow straight off, making sure it clears the carburetor's threaded rods.
Pull the carburetor spacer straight off, making sure it clears the threaded rods.
Pull the choke lever straight up to remove it from the carburetor.
Press and hold down the fuel valve's safety lock button.
Begin to turn the fuel valve knob counter-clockwise, continuing to hold down the safety lock button until the knob clears the button.
Place a small gasoline-safe container under the drain spout.
Turn the fuel valve knob counter-clockwise until it faces downward to drain any gasoline that may be remaining in the carburetor.
Use a pair of needle nose pliers to squeeze and loosen the spring hose clamp on the fuel supply hose.
Move the clamp up 2-3 cm so it's not clamping down onto the end of the tube.
Grab onto the end of the fuel supply hose and pull it straight up to disconnect it from the carburetor.
Pull the carburetor halfway out, but do not completely remove it yet.
Grab the throttle return spring and push it down to point the tip of the hook downward.
Apply an upward motion to lift the tip of the hook out of its connector on the carburetor.
Grab the governor rod and lift it straight up to remove it from the carburetor.
Pull the carburetor straight off of the threaded rods to remove it.
Еще один человек закончил это руководство.
