Honda Fit Reset Oil Life Indicator Replacement
Выберете то, что вам нужно
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
Заключение
You did it!
19 участников успешно повторили данное руководство.
Jasen Friedle
Участник с: 08/25/14
3 821 Репутация
Автор 3 руководств
5 Комментариев
Great. I did it—and I’m a girl!!
pthompso99 - Ответить
Excellent! Glad to hear it.
Jasen Friedle - Ответить
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - Ответить
And how can I start the car that it won't start
sbukataake - Ответить
Have you tried changing your blinker fluid?
neegnorg -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 130
За последние 30 дней: 512
За всё время: 75,164
