Введение
This guide shows how to remove and replace the oil seal on the transmission input shaft in a Honda FRC800K1A Rear Tine Tiller.
Drain the oil from the transmission before beginning this process.
After completing this procedure, refill the transmission with 5.3 quarts of SAE 10W-30 oil.
Выберете то, что вам нужно
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Use a 14 mm socket to remove the bolt securing the outer belt cover.
Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
Pull the tine engagement lever to put belt tension on the transmission pulley.
With the belt taut, use a 12 mm socket to loosen the transmission pulley bolt without fully removing it.
Push the V-belt towards the transmission pulley to release tension.
Slip the V-belt off of the groove in the pulley.
Pull the V-belt down and out of the way of the two-prong belt guide.
Push the V-belt around and off of the motor pulley to remove.
Use a 12 mm socket to remove the two bolts securing the belt guides to the inner belt cover.
Use a 10 mm socket to remove the bolt securing the inner belt cover to the frame.
Use a 14 mm socket to loosen the two bolts securing the guard to the frame.
These bolts have corresponding 14 mm nuts on their opposite ends. You will need to keep the bolts steady with a wrench or socket for the nuts to become loose.
Remove both nuts, but do not remove the bolts yet.
Use a 12 mm socket to remove the motor and transmission pulley bolts.
Hold the pulleys steady to more easily remove the bolts.
Pull the transmission pulley straight off of the splined shaft to remove.
Use snap ring pliers to remove the snap ring securing the tensioner pulley to its shaft.
Use needle nose pliers to remove the three wire clips securing various cables to the back of the inner belt cover.
Use a 12 mm socket to remove the two remaining inner belt cover bolts behind the transmission pulley.
Pull the inner belt cover clear of the motor and transmission shafts.
Remove the inner belt cover.
Wedge a pick tool between the input shaft and the oil seal.
Pull firmly in the direction of the shaft to loosen the oil seal.
Remove the oil seal.
Refill the transmission with 5.3 quarts of SAE 10W-30 oil.
Еще один человек закончил это руководство.
