Введение
This guide shows how to remove and replace the V-Belt on a Honda FRC800K1A Rear Tine Tiller.
Выберете то, что вам нужно
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Use a 14 mm socket to remove the bolt securing the outer belt cover.
Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
Push the V-belt towards the transmission pulley to release tension.
Slip the V-belt off of the groove in the pulley.
Pull the V-belt down and out of the way of the two-prong belt guide.
Push the V-belt around and off of the motor pulley to remove.
Еще один человек закончил это руководство.
