Введение
Some soldering will be required in order to complete the speaker replacement.
Выберете то, что вам нужно
Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
Remove the back cover by carefully pushing the battery connector through the hole in the cover.
With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
Connect the battery and turn the power on to test proper connection of the new speaker.
3 участников успешно повторили данное руководство.
