Введение
This guide will walk you through the removal of your fan motor. It should be fairly easy, although you will need to crimp the wires to remove the motor.
Выберете то, что вам нужно
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
Once the screws are removed, lift the motor off its base.
Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
2 участников успешно повторили данное руководство.
2 Комментариев
Do you know where I can find the fan motor replacement?
