Введение
This guide will show a step-by-step process of how to remove and replace your old, broken, or dirty fan blades. It will also provide some tips to stop your fan from making rattling noises.
Safety Tips:
- Unplug your fan– you should never attempt to clean a fan while it’s plugged in.
- It is highly recommended to wear a mask and/or protective eyewear to protect yourself from dust.
- Make sure not to drop any of the lubricant greases in the ball bearing.
This process only applies to traditional tower fans. Therefore, if you have a blade-less fan, the process will vary.
Good luck!
Выберете то, что вам нужно
Lay the fan horizontally and remove the base by unscrewing the locking nut from the fan housing.
Remove the 3” wing screw on the bottom of the fan; then, remove the four 3" screws on the top of the fan.
Carefully open up the fan housing in half by pulling the front and back parts away from each other. You should now be able to see the motor attached with the fan blade.
Remove the screw connecting the motor shaft with the bottom half of the fan blade.
Remove the two screws connecting the metal bracket with the fan blade and remove the metal bracket.
To carefully remove the fan blades, grab the fan blades firmly and lift them toward yourself.
Gently clean the inner surface of the fan with a cloth or a vacuum cleaner to remove all the dust that has collected through usage.
To fix the rattling noise, carefully apply lubricating grease around the blade drum’s shaft.
To stop the new fan blades from vibrating, tighten the screws around the metal bracket and motor shaft. Then, place the other half of the tower casing and screw it in place.
To reassemble your device, follow these instructions in reverse order. Follow this guide to self-service your tower fan yourself saving lots of money!
Еще один человек закончил это руководство.
