Введение
This guide will show you how to replace the motor that turns the brush roller in the nozzle. You might need to do this if the brush roll is no longer spinning. Make sure that the device is turned off and the battery removed from it.
Выберете то, что вам нужно
Detach the rolling assembly from the body by pushing the button found at the base.
3 участников успешно повторили данное руководство.
3 Комментариев
Thank you for the photos! They’ve been helpful as I’m putting my Linx back together and can’t quite remember how the wires go back in the nozzle assembly. When putting the top plate back on, it’s a very tight fit where the top will be pushed up if maligned.
In the elbow part- It looks like the positive lead is on the left in your photo, but it would be helpful if you would add that specification to your step.
Great Job!
