Введение
Nozzle that releases the water/solution and sucks up dirty water. Also where the hose can be attached/detached. This nozzle may need to be cleaned after usage, so removal is necessary.
Инструменты
No tools required.
Запчасти
Никакие детали не требуются.
  1. Unlatch the grey switch labeled “Tank Release”.
    • Unlatch the grey switch labeled “Tank Release”.
  2. Gently pull on the water tank until it releases from the base.
    • Gently pull on the water tank until it releases from the base.
    • Lift the switch that was covered by removing the tank.
    • Pull the nozzle until out of place.
Заключение
Anthony Margulis
Участник с: 22.01.2018
85 Репутация
1 Guide authored
Команда
Cal Poly, Team S16-G4, Banghart Winter 2018 Member of Cal Poly, Team S16-G4, Banghart Winter 2018
CPSU-BANGHART-W18S16G4
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 57
