Введение
Use this guide to replace the brush in the head of the vacuum.
Выберете то, что вам нужно
Place the vacuum on its back.
On the bottom right side, push the red lever to the left.
Remove the plastic cover.
Grab the red switch under the brush and push left.
Then remove the plastic base plate.
Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
Pull the clear plastic away from the head of the vacuum.
Slide the belt off the metal rod with your finger.
Pull the brush free.
