Введение
Instructions on how to replace the height adjustment wheels at the bottom of the vacuum.
Выберете то, что вам нужно
Place the vacuum on its back.
Push the red switch to the left.
The black cover will then pop out. Remove the cover.
Locate the red switch near the head of the vacuum.
Push the switch left.
This will pop out the plastic base plate. Remove the plate from the vacuum.
Use a Phillips #1 screwdriver to remove the screws from the right side of the white plastic frame.
Pull the white plastic frame away from the vacuum.
Slide the vacuum belt off the metal rod.
Pull the brush off the vacuum.
Pop off the right side of the white frame.
Pull down the blue hinge and roller.
Pull free the roller from the vacuum.
2 Комментариев
HOOVER 30310 brush roller stops when the handle is released for vacuuming. Begins again when handle raised and locked into upright position.
Hoover wind tunnel three pet quick pass. Roller spins in an upright position (locked handle). Foot pedal tensioner and off works, but will not stay in off position.
