Введение
This guide will help you into replacing the inlet filter in the body of the vacuum.
Выберете то, что вам нужно
Remove the frame of the vacuum by pinching the tab down and pulling the frame away from the vacuum body.
Locate the large sieve at the bottom of the vacuum body.
Lift off the sieve, separating it from the filter.
Remove the old inlet filter from the vacuum body and replace with the new filter.
Почти готово!
Заключение
