Введение
The primary air filter is in the vacuum's dust cap and prevents dust from being sucked out of the dust cup.
It's designed to be easily cleaned or replaced, so it's a quick process.
If your filter merely needs to be cleaned, you can follow this guide, but instead of replacing the filter you can rinse it under a faucet and reinstall it.
Выберете то, что вам нужно
Press button on the top of the dust cup and pull back.
Remove dust cup from vacuum
Lift up on fabric flap to remove filter from vaccum
If you wish to clean the filter rather than replace it, it can be washed under a faucet.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Can I rinse it with warm water and soap? Or just warm water?
