Hornady Lock-n-load Auto Charge L298n Replacement
Выберете то, что вам нужно
  1. Hornady Lock-n-load Auto Charge L298n Replacement, Overview: шаг 1, изображение 1 из 1
    • Horandy Auto Charge
  2. Hornady Lock-n-load Auto Charge L298n Replacement: шаг 2, изображение 1 из 2 Hornady Lock-n-load Auto Charge L298n Replacement: шаг 2, изображение 2 из 2
    • Empty Powder out
    • Remove anything that will fall out when you turn it over to get to the 6 phillips screws in the botton
    • remove the 4 round foam feet to exposed the screws. unscrew the 6 screws
  3. Hornady Lock-n-load Auto Charge L298n Replacement: шаг 3, изображение 1 из 1
    • slowly separate the black bottom from the red top. there is a motor connecter, screen connector, and 2 connector for the keypad.
  4. Hornady Lock-n-load Auto Charge L298n Replacement: шаг 4, изображение 1 из 1
    • There is 1 circuit board and you can see the l298n on the right side. take circiut board out and unsoder the l298n. install New L298n with Heat sink . and reassemble.
  5. Hornady Lock-n-load Auto Charge L298n Replacement, Damaged L298N: шаг 5, изображение 1 из 1
    • You can see the damage to the L298N
    • required a new Motor Controller IC. This happened loading 300 Cartridges back to back. Duty Cycle was to much. ADDED heat sink is a must if loading may Cartridges!!!
    • when testing after new IC was installed
    • Motor would Jerk and was not smooth. disassemble motor and clean brushes.
Заключение
3 участников успешно повторили данное руководство.
Brent Felzien
Участник с: 10/16/18
187 Репутация
1 руководство автора
2 Комментариев
Fantastic article. I have the identical complication but need a new board due to one of the internal wires being severed. I am unable to locate any source for the replacement of the board, plus no item number for ID on the board. Any help is greatly appreciated. Hornady has a Terrible Attitude and admits no faults. I had to return this unit for a warranty on the initial purchase due to a lack of calibration on the 50 side. Used it 4 times and it is DOA. It is never left on or with a power source connected.
Thomas M Smythe - Ответить
My numbers 7,8,9,and unit buttons don't work I've tried looking for part to fix it but can't find anything on it
Eddie Cross - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 34
За всё время: 2,864
