Hot Wheels AI Intelligent Race System Controller Transmitter Replacement
Выберете то, что вам нужно
  1. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement, Controller Transmitter: шаг 1, изображение 1 из 1
    • Locate and remove the six screws on the back of the controller. Remove screws with a #J1 Philips head screwdriver.
  2. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: шаг 2, изображение 1 из 1
    • With the controller facing down remove the top casing from the bottom. Do this by popping the casing lose which will expose the inside circuits.
  3. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: шаг 3, изображение 1 из 1
    • With the circuits exposed locate the transmitter at the top of the controller. It is green hue in comparison to the rest of the blue circuits. Check the transmitter for damage or disconnected wires.
  4. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: шаг 4, изображение 1 из 1
    • If transmitter has broken or has disconnected wires it may need replacement. Wires can easily break loose from the transmitter. The wires can easily be reinserted by sticking the wire back into its original slot.
  5. Hot Wheels AI Intelligent Race System Controller Transmitter Replacement: шаг 5, изображение 1 из 1
    • If the transmitter is damaged, replace it by sliding the circuit down from its slot. Check for damage or burned out circuit.
    • Replace transmitter circuit with a new one by reinserting it into the original slot.
Заключение
Luke Marshall
Участник с: 09/07/18
628 Репутация
Автор 4 руководств
Команда
Appalachian State University, Team S1-G2, Menagarishvili Fall 2018 Участник Appalachian State University, Team S1-G2, Menagarishvili Fall 2018
APSU-MENAGARISHVILI-F18S1G2
2 членов
Автор 6 руководств
1 Комментарий к руководству
Give the part numbers so we can source the circuits and change the devices if needed. Also can anyone extract the rim? I believe the rim being used is way low quality.
Luis Vitorio Cargnini - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 37
За всё время: 1,087
