Введение
This guide will walk you through how to remove the back panel of the Hott T725-8G.
Caution: The speaker is attached to both the front and back panels, so be careful when separating the halves.
Выберете то, что вам нужно
Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
