Введение
This guide will walk you through the process of replacing a malfunctioning motherboard in a Hott T725-8G.
Выберете то, что вам нужно
Carefully remove the black electrical tape connecting the motherboard to the ribbon wire.
Squeeze both sides of the protector over the ribbon wire to release it.
Use the tweezers to gently remove the ribbon wire from the holder.
Repeat steps for all three ribbon wires shown.
Use the #000 Phillips screw driver to remove all three 2.2mm screws attached to the mother board.
You are now able to remove the motherboard.
Еще один человек закончил это руководство.
