Введение
Learn how to replace the battery with this guide. Any power related problems may need a battery replacement. For this guide, you will need a Phillips #2 screwdriver and a metal spudger.
Выберете то, что вам нужно
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Lift the shell with the speaker grille.
Unplug the speaker.
Unplug the LEDs.
Unplug the power button
Unplug the charging port.
Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
Use the spudger to pry the battery loose from the adhesive.
Pull and wiggle the battery completely off of the adhesive using your hands.
Remove the battery from the body.
Еще один человек закончил это руководство.
