Введение
The Bluetooth speaker connects to your device to play music while you ride the Hover-1. You will need a Phillips #2 screwdriver to replace the Bluetooth speaker.
Выберете то, что вам нужно
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Lift the shell with the speaker grille so the speaker can be accessed.
Remove the three 14 mm Phillips #2 screws holding the speaker to the bottom left shell.
Pull off the bracket holding the speaker in place.
Place the speaker to the side so that the tab on the cable connector to the sound card can be accessed.
2 участников успешно повторили данное руководство.
