Введение
If you need to access the internals of your Hover-1, or want to replace the case, use this guide. It will show you how to remove the case. You will need a Phillips #2 screwdriver.
Выберете то, что вам нужно
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Lift the shell with the speaker grille.
Unplug the speaker.
Unplug the LEDs.
Unplug the power button
Unplug the charging port.
