Введение
This guide will show you how to replace the LED headlights on the front of the Hover-1 Chrome. You will need a Phillips #2 screwdriver.
Запчасти
Никакие детали не требуются.
  1. Flip the Hover-1 Chrome upside down.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Lift the shell without the speaker grille and unplug the battery.
    • Lift the shell without the speaker grille and unplug the battery.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
Заключение
Nick McGuire
Участник с: 08.10.2018
539 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S4-G1, White Fall 2018 Member of Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 5
За всё время: 36
