Введение
To fully access all parts of the Hover-1 Chrome, the entirety of the outer shell must be removed. This guide will go over how to completely remove the outer shell.
Выберете то, что вам нужно
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Lift the shell with the speaker grille.
Unplug the speaker.
Unplug the LEDs.
Unplug the power button
Unplug the charging port.
Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
Free the cables held atop the bracket holding the battery in place.
Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
Pull the battery bracket free.
