Запчасти
Никакие детали не требуются.
  1. To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Now pull the black protective cover off the board.
    • Now pull the black protective cover off the board.
    • Locate the battery.
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
    • Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
    • Remove the unwanted spring and place your new spring back into the hole.
Заключение
Jace Oppenlander
Участник с: 04.10.2018
521 Репутация
Автор 4 руководств
Команда
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 40
За всё время: 59
