Введение
If you are ever in the situation where any of your Coast wheels are needed to be replaced don't hesitate replacing them. This does not require any difficult steps but it is important for your safety along with others around you.
Выберете то, что вам нужно
Find the Socket wrench located in the Hover-1 Coast packaging.
Use the 9/16 inch side to loosen the skateboard nut by turning counterclockwise.
To avoid losing any parts, place them on a flat surface.
Slide the unwanted wheel off the axle.
Slide the new wheel on the axle.
