Введение
This guide is designed to help you replace a broken or damaged brake switch. All you will need is a #0 and #2 Phillips screwdriver to remove the screws in this guide
Выберете то, что вам нужно
Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
2 участников успешно повторили данное руководство.
6 Комментариев
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Hi, I’m looking for a Hover-1 Eagle left handle? Do you where can I find it? Thanks
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
