Hover-1 Folding E-Scooter Brake Switch Replacement
Выберете то, что вам нужно
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: шаг 1, изображение 1 из 1
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: шаг 2, изображение 1 из 2 Hover-1 Folding E-Scooter Brake Switch Replacement: шаг 2, изображение 2 из 2
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: шаг 3, изображение 1 из 3 Hover-1 Folding E-Scooter Brake Switch Replacement: шаг 3, изображение 2 из 3 Hover-1 Folding E-Scooter Brake Switch Replacement: шаг 3, изображение 3 из 3
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
Заключение
2 участников успешно повторили данное руководство.
Brittani Kealoha
Участник с: 10/08/18
251 Репутация
1 руководство автора
Команда
Cal Poly, Team S15-G5, White Fall 2018 Участник Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 членов
Автор 5 руководств
6 Комментариев
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - Ответить
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - Ответить
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - Ответить
Looking new break switch.where we will get?. please reply.
Vitesh - Ответить
Looking for a throttle switch. Know where I can find one?
Mara - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 31
За всё время: 4,647
