Введение
Is your deck on your Hover-1 Folding eScooter damaged? If so here is a guide to help you replace it with a new one.
Запчасти
Никакие детали не требуются.
  1. Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise. The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Slide off the plastic side panel. Slide off the plastic side panel. Slide off the plastic side panel.
    • Slide off the plastic side panel.
  3. Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Slide off the other plastic side panel. Slide off the other plastic side panel. Slide off the other plastic side panel.
    • Slide off the other plastic side panel.
  6. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  7. On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
  8. Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise. Twist the screwdriver clockwise to reassemble.
    • Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
    • Twist the screwdriver clockwise to reassemble.
    • There are also two nuts that secure the screws.
  9. Wobble to remove the brake step. Wobble to remove the brake step. Wobble to remove the brake step.
    • Wobble to remove the brake step.
  10. Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise. Twist the screwdriver clockwise to secure the screws.
    • Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise.
    • Twist the screwdriver clockwise to secure the screws.
  11. Remove the brake pad. Remove the brake pad. Remove the brake pad.
    • Remove the brake pad.
  12. Hold the two 10mm nuts in place with a 10mm wrench. Remove the two 33mm bolts connected to the 10 mm nuts by turning a hex 4.0 screwdriver counterclockwise. The nuts are on the bottom of the deck.
    • Hold the two 10mm nuts in place with a 10mm wrench.
    • Remove the two 33mm bolts connected to the 10 mm nuts by turning a hex 4.0 screwdriver counterclockwise.
    • The nuts are on the bottom of the deck.
    • Turn clockwise to reassemble the bolts.
  13. Fold the scooter by releasing the latch and pushing the handlebars to the rear of the device. Fold the scooter by releasing the latch and pushing the handlebars to the rear of the device.
    • Fold the scooter by releasing the latch and pushing the handlebars to the rear of the device.
  14. Hold the two hex nuts in place with a 10mm wrench. Remove the next two 33 mm bolts attached to the 10 mm hex nuts by turning a hex 4.0 screwdriver counterclockwise. The deck will fall off after you remove the final bolts.
    • Hold the two hex nuts in place with a 10mm wrench.
    • Remove the next two 33 mm bolts attached to the 10 mm hex nuts by turning a hex 4.0 screwdriver counterclockwise.
    • The deck will fall off after you remove the final bolts.
    • Turn the hex bit clockwise to reassemble.
Заключение
To reassemble your device, follow these instructions in reverse order and use the new deck instead.
Nicolo DiFronzo
Участник с: 08.10.2018
205 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S15-G5, White Fall 2018 Member of Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 5
За всё время: 80
