Hover-1 H1 Charging Port Replacement
Выберете то, что вам нужно
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: шаг 1, изображение 1 из 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: шаг 2, изображение 1 из 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: шаг 3, изображение 1 из 2 Hover-1 H1 Charging Port Replacement: шаг 3, изображение 2 из 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: шаг 4, изображение 1 из 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: шаг 5, изображение 1 из 2 Hover-1 H1 Charging Port Replacement, Charging Port: шаг 5, изображение 2 из 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: шаг 6, изображение 1 из 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: шаг 7, изображение 1 из 2 Hover-1 H1 Charging Port Replacement: шаг 7, изображение 2 из 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: шаг 8, изображение 1 из 2 Hover-1 H1 Charging Port Replacement: шаг 8, изображение 2 из 2
    • Pull the charging port to the left through the shell.
Заключение
Madeline David
Участник с: 10/08/18
280 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G6, White Fall 2018 Участник Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 членов
Автор 7 руководств
Один комментарий
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 53
За всё время: 3,866
