Введение
This guide explains how to remove the sensor assembly for your Hover-1 H1 hover board.
Выберете то, что вам нужно
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Puncture the two black stickers by using the tip of a screwdriver.
Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
Remove the hot glue holding in the connectors with a utility knife.
Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
5 участников успешно повторили данное руководство.
