Hover-1 H1 Shell Replacement
Выберете то, что вам нужно
  1. Hover-1 H1 Shell Replacement, Bottom Shell: шаг 1, изображение 1 из 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Shell Replacement: шаг 2, изображение 1 из 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Shell Replacement: шаг 3, изображение 1 из 2 Hover-1 H1 Shell Replacement: шаг 3, изображение 2 из 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Shell Replacement: шаг 4, изображение 1 из 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Shell Replacement, LED Headlights: шаг 5, изображение 1 из 1
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 Shell Replacement: шаг 6, изображение 1 из 1
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 Shell Replacement: шаг 7, изображение 1 из 1
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
  8. Hover-1 H1 Shell Replacement, Charging Port: шаг 8, изображение 1 из 2 Hover-1 H1 Shell Replacement, Charging Port: шаг 8, изображение 2 из 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  9. Hover-1 H1 Shell Replacement: шаг 9, изображение 1 из 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  10. Hover-1 H1 Shell Replacement: шаг 10, изображение 1 из 2 Hover-1 H1 Shell Replacement: шаг 10, изображение 2 из 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  11. Hover-1 H1 Shell Replacement: шаг 11, изображение 1 из 2 Hover-1 H1 Shell Replacement: шаг 11, изображение 2 из 2
    • Pull the charging port to the left through the shell.
  12. Hover-1 H1 Shell Replacement, Power Button: шаг 12, изображение 1 из 1
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
  13. Hover-1 H1 Shell Replacement: шаг 13, изображение 1 из 2 Hover-1 H1 Shell Replacement: шаг 13, изображение 2 из 2
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
  14. Hover-1 H1 Shell Replacement: шаг 14, изображение 1 из 1
    • Pull the power button through the hole in the shell.
  15. Hover-1 H1 Shell Replacement, Shell: шаг 15, изображение 1 из 3 Hover-1 H1 Shell Replacement, Shell: шаг 15, изображение 2 из 3 Hover-1 H1 Shell Replacement, Shell: шаг 15, изображение 3 из 3
    • Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
    • Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
  16. Hover-1 H1 Shell Replacement: шаг 16, изображение 1 из 1
    • Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
  17. Hover-1 H1 Shell Replacement: шаг 17, изображение 1 из 1
    • Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
    • Repeat for the left side of the shell.
  18. Hover-1 H1 Shell Replacement: шаг 18, изображение 1 из 1
    • Lift the shell to remove it from the chassis.
Заключение
Sara Passantino
Участник с: 10/08/18
326 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G6, White Fall 2018 Участник Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 1,179
