Введение
This guide explains how to replace the shell of your Hover-1 H1 hoverboard.
Выберете то, что вам нужно
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Puncture the two black stickers by using the tip of a screwdriver.
Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
Remove the horizontal light by using your fingers to pull the light up out of the shell.
Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
Pull the cable through the center section of the hoverboard.
Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
Repeat for the left side of the shell.
