Введение
Are your wheels experiencing resistance while turning? This is a guide to show you how to check and replace the wires that connect the wheel to the motherboard. This guide requires a Phillips #2 and a Phillips #1 screwdriver, and a 6 mm hex key.
Выберете то, что вам нужно
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
Lift the board to reveal the connections on the bottom.
Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
Remove the clip by squeezing the latch that holds the clips together while pulling apart.
Remove the clip by squeezing the tab while pulling the clip apart.
