Введение
Is one side of the hoverboard not functioning, or unresponsive? This is a guide to show you how to replace the wheel, or motor (which is apart of the wheel) on the Hover-1 Horizon. This guide requires a Phillips #2 and a Phillips #1 screwdriver, and a 6mm hex key.
Выберете то, что вам нужно
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
Lift the board to reveal the connections on the bottom.
Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
Remove the four 30mm Hex #6 screws.
Lift away the silver bracket and set it to the side.
Disconnect the first clip by squeezing the latch that hold the clips together while pulling apart.
Disconnect the second clip by squeezing the tab while pulling the clip apart.
Еще один человек закончил это руководство.
