Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your Hover-1 Liberty is not holding a charge and there is no problem with the charging cord, then the battery needs to be replaced. In this guide, the side of the hoverboard with the words Hover-1 printed on it will be referred to as the right side.
Выберете то, что вам нужно
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Disconnect the large red and black wire from the battery by pulling apart the connector.
Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
Еще один человек закончил это руководство.
