Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove the bottom cover by lifting it away from the hoverboard.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Disconnect the large red and black wire from the battery by pulling apart the connector.
Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
Remove the bracket by pulling it upwards, away from the hoverboard.
Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
Еще один человек закончил это руководство.
