Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The first step to replacing any internal component in the hoverboard is to remove the external plastic covers. You will need a Phillips #2 screwdriver with a long shaft for this guide.
Запчасти
Детали не указаны.
  1. Flip the hoverboard over so the labels are facing upwards. Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Remove the bottom cover by lifting it away from the hoverboard. The cover on the side without the battery has two wires connecting the power button and charging port.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  4. Remove one connector from the non-battery side circuit board. Remove the next connector from the non-battery side circuit board. To remove the connectors, pinch the plug and pull away from the circuit board.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
Заключение
Еще один человек закончил это руководство.
Patrick Bacon
Участник с: 08.10.2018
366 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S13-G2, White Fall 2018 Участник Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 членов
Автор 4 руководств
Один комментарий
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 30
За всё время: 1,548
