Введение
Hoverboards were a thing of science-fiction, but since introduced in 2013 they became a sensation. The battery is a major component in providing electricity to the hoverboard. When the battery gets damaged it is not that difficult to replace it in order to keep the board running.
Выберете то, что вам нужно
Remove the twenty screws from the top outer cover using a Phillips #1 screwdriver.
Lift the left and right sides of the outer cover away from the rest of the hoverboard.
Move the plastic cover from the top of the battery.
Unplug the cables that connect to the battery and remove the battery from the hoverboard.
To reassemble the device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
