Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your Nomad does not charge, dies quickly, or does not drive predictably, your battery may be dying or damaged. Follow this guide to replace the battery in the Hover-1 Nomad.
Выберете то, что вам нужно
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Use a nylon spudger to pry the metal handle away from the outer shell.
Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
Lift the hoverboard off the metal handle.
Repeat for the handle on the other side of the hoverboard.
Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
Charging port wires
Speaker assembly wires
Power button wires
Headlight wires
Cut the two zip ties around the bundle of wires with cutting pliers.
Disconnect the circuit boards from the battery by pulling both battery connectors apart.
Disconnect the following wires connecting the circuit boards to the sensors and motors:
Disconnect the white connectors by pinching the tab and pulling up on the connectors.
Disconnect the black connectors by pulling the two sides apart.
Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
Remove the four 14mm Phillips #1 screws in the corners of each circuit board by turning the screwdriver counterclockwise.
Remove the four 15mm screws from the battery cage with a Phillips #2 screwdriver.
Еще один человек закончил это руководство.
