Hover-1 Nomad LED Headlights Replacement
Выберете то, что вам нужно
  1. Hover-1 Nomad LED Headlights Replacement, Outer Shell: шаг 1, изображение 1 из 3 Hover-1 Nomad LED Headlights Replacement, Outer Shell: шаг 1, изображение 2 из 3 Hover-1 Nomad LED Headlights Replacement, Outer Shell: шаг 1, изображение 3 из 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad LED Headlights Replacement: шаг 2, изображение 1 из 3 Hover-1 Nomad LED Headlights Replacement: шаг 2, изображение 2 из 3 Hover-1 Nomad LED Headlights Replacement: шаг 2, изображение 3 из 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad LED Headlights Replacement: шаг 3, изображение 1 из 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad LED Headlights Replacement: шаг 4, изображение 1 из 2 Hover-1 Nomad LED Headlights Replacement: шаг 4, изображение 2 из 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad LED Headlights Replacement, LED Headlights: шаг 5, изображение 1 из 1
    • Remove the two 13mm Phillips #1 screws by rotating the screwdriver counterclockwise.
    • Repeat on the other side of the hoverboard to remove the other headlight.
  6. Hover-1 Nomad LED Headlights Replacement: шаг 6, изображение 1 из 1
    • Pull the headlight up and off the outer shell.
Заключение
Еще один человек закончил это руководство.
Samuel Frazee
Участник с: 10/08/18
1 015 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S15-G1, White Fall 2018 Участник Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 членов
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 377
