Введение
If your Hover-1 Titan battery will no longer hold a charge or your device will not turn on, use this guide to remove and replace your battery.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
Еще один человек закончил это руководство.
