Fix Your Stuff
Right to Repair
Parts & Tools
Запчасти
Детали не указаны.
  1. Flip the hoverboard so the bottom is facing up. The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Grip the bottom left panel and lift up to remove. Grip the bottom left panel and lift up to remove. Grip the bottom left panel and lift up to remove.
    • Grip the bottom left panel and lift up to remove.
Заключение
Dana Ebe
Участник с: 08.10.2018
196 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S15-G4, White Fall 2018 Участник Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 30
