Введение
If the wheel of your hoverboard is damaged or your hoverboard does not spin on one side, use this guide to replace the wheel and motor in the Hover-1 Titan.
Инструменты
Запчасти
Детали не указаны.
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
Unplug the green wires by gripping the wire close to the connectors and pulling apart.
Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
Еще один человек закончил это руководство.
