Введение
Is your Hover-1 riding slowly, dying while riding, or not going as fast? If you are facing these problems, a simple replacement of the battery could solve your issues. You will need a Phillips #1 screwdriver to remove the screws.
Выберете то, что вам нужно
Orient the hoverboard so that the pads are facing down.
With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
Carefully remove the shell, lifting directly up.
Remove the 4 screws around the battery on the case using the Phillips #1 screwdriver.
Remove the case that houses the battery.
Pinch and pull apart the connecting black and yellow cable.
Remove the battery from the hoverboard.
To reassemble your device, follow the instructions in step 1 in reverse order.
Еще один человек закончил это руководство.
Один комментарий
Merci pour tous ces conseils précieux, j’ai pu réparer ma batterie de Hoverboard : https://hover-store.fr/batterie-hoverboa...
