Введение
A broken light on a Hover-1 XLS bike is a safety hazard, especially if you use the bike when dark. Do not ride the bike with a broken tail light.
Выберете то, что вам нужно
Remove the seat by removing the six 16mm screws with a Phillips #2 screwdriver.
Disconnect the wires by pushing the levers on either side of the connector and on top.
Remove the seat from the bike.
Use a Phillips #2 screwdriver to remove the four 10mm screws on the bottom of the back seat.
Pull the light from behind the bottom of the seat frame. Pull the wiring all the way through.
Еще один человек закончил это руководство.
